Good Morning! Is it possible to to zoom to a location from a drop down menu selection?
696
04-12-2018 05:20 AM
ScottStepro1
Is it possible to pre-load points into 123, link them to a drop down menu that once selected will change the map view relative to that point?? Script?
Thanks!
JamesTedrick
Esri Esteemed Contributor
Hi Scott,
Yes, it is possible to calculate the locations based on a dropdown.  Geopoints receive a string that consists of <latitude>_<longitude>_<altitude>_<accuracy>, with the altitude and accuracy components optional.  See Geopoints—Survey123 for ArcGIS | ArcGIS for more information, as well as the following samples available in Survey123 Connect:
  • Calculate Location from a Choice List
  • Calculate Location from CSV2
PabloGallego1
Hi James,
From survey connect it works perfectly but  when I publish and use it on my pc to enter data it doesn't work... Only work on the app.
I find this option very useful, is there any solution if you enter data from your pc?
JamesTedrick
Hi Pablo,
There is a version of Survey123 app available for Windows and Mac.  Additionally, you could use the web form version that's created after publishing as well.
Aurelija_RutaViluckyte
Hello @JamesTedrick ,
Is it possible to do the same with a geoshape question? To populate geoshape question map with locations from choice list?
I feel a little stuck here ... any guidance would be very much appreciated!
