Go to Inbox When Opening Survey 123
424
08-12-2022 04:21 PM
MeleKoneya
I am using a URL to open a particular survey with something like this
https://survey123.arcgis.com/share/5dc0c344bda66bf70def85948b?portalUrl=https://GISServer.maps.arcgi...
The portlaURL parameter is helpful for logging the user in quicker
I would also like to be able to go straight the the inbox.     I do not have a particular survey for the user until they enter a search term.
Is there a parameter that will send me straight to the inbox?   Currently the Survey Opens at the point where they can create a new survey, but we don't want them to do that.
Mele
ScottBrown1
Try the following URL:
arcgis-survey123://?itemID=5dc0c344bda66bf70def85948b&action=edit&folder=inbox
Assuming the example you gave is your survey, I used your itemID. I do not have access, but this URL works with my surveys. Just replace the itemID number with the survey you’re trying to work with.
Let me know how it works for you!
MeleKoneya
Scott
Thanks for the reply!   That does take me right to the inbox.   That's great.   The only thing missing is that our survey is not public so the user needs to login first.   I am working on that part.    But so far so good.   Thanks!
