GeoShape default map location
8817
16
07-23-2019 01:00 PM
RussellSturm
I'm trying my first survey with the geoshape.  Is it possible to set the default location for the map when opening the geoshape question?  I tried in both the default and calculations columns in the excel form but neither appears to work.  I was hoping it would work like the geopoint question where I can set the location.  Also, will geoshape use the default zoom level from the settings of the survey?
Shwu-jingJeng
Hi Russell,
Thanks for your form. I was able to repro your issue at my end. As geoshape is still in Beta, we will invenstigate if there is issue with default vale setting for geoshape and will address this issue.
And for your information, I saw you are using a repeat for your geoshape and we just address an issue with 3.5 hot fix release to fix the geopoint calculation within the repeat(not geoshape though).
Shwu-jingJeng
Hi Russell,
You should be able to set the default location from Survey123 Connect>Setting>Map tab to set the home location and the zoom level.
RussellSturm
I have a default location and zoom set in Survey123 Connect>Settings>Map tab.   I tried a geopoint question and those defaults do change the geopoint.  However, they don't seem to do anything to the geoshape question.  I have also tried setting the lat/long in the default column for the question and the calculation column.  Neither of those appear to change the map location either.
Shwu-jingJeng
It works for me when creating geoshape using a basic template deployed from Survey123 Connect. Could you share your xlsx form for us to take a look here?
RussellSturm
If I removed my default value for the geoshape question and just use the survey default the map is at the location for based upon the survey settings.   However, the survey is used globally so I can't just use one location.  I want to set the map location based upon a known lat/long for the survey.  I use a concat like this:  concat(${centroidlatitude},' ',${centroidlongitude})
That syntax works for the geopoint question but doesn't seem to for the geoshape.
Shwu-jingJeng
Hi Russell,
Could you share your XLS form or take a screenshot of how you set the default value in the form?
RussellSturm
This is a slimmed down version of the survey, but you should be able to see what I'm trying to do.  The geopoint question works, the geoshape does not.
Shwu-jingJeng
Hi Russell,
PhilipMarty
Is this available yet? Not seeing any documentation, and it's been several years. It's a needed enhancement. Thank you
RussellSturm
Thanks for the feedback and verification of the issue.  We'll wait for a new release that addresses this issue as we move forward.
