Hello
I have linked two Web Maps to my survey using Survey123 Connect's Linked Content tab to be used for a geopoint question. When I click on the Map tab and look at the Preview and Detailed Map I am able to see both maps in the basemap gallery and have set one as the default. When I preview the geopoint question in Connect I am able to select between the two linked web maps, however I do not see any other of the ESRI default basemaps. My biggest issue is when I test the survey on my mobile phone, using the field app, the geopoint question only has default ESRI basemaps and not the maps that I linked. I am online when I test the field app and my map settings are switched to Standard. I am also not signed into my ArcGIS Online account as this survey will be distributed to volunteers, many of whom do not have AGOL accounts. I want to test it as they would see and experience it to make sure it all works. I will also be creating offline maps, but that is a step removed from the online maps working.
Maybe there is something that I need to adjust on the maps in ArcGIS Online?
