Error Generating Survey 123 Reports : Error Reads "The task failed because all reports failed to run printIndividual"
8269
13
06-24-2022 01:06 AM
SindiswaMsubo
Hi ! I need assistance please.
I have been using Survey 123 Website to generate feature reports without a problem, for the past couple of months. However recently whenever I try generate a report it gives me the error : "The task failed because all reports failed to run printIndividual"
I have removed the initial report template I created and tried using the default template provided to generate the reports again, however I still get the same issue. I need to be able to generate these reports ASAP. The Reports need to be submitted by the end of next week.
Any Ideas on how I can solve this issue?
ZacharySutherby
Hello @SindiswaMsubo
Would you be able to pass along your XLSForm for testing on our end? I would suggest reaching out to Esri Technical Support to assist with troubleshooting the behavior.
Thank you,
Zach
SindiswaMsubo
Hi @ZacharySutherby,
Thank you for your willingness to assist. I have attached the xls forms below. Also please note that I was able to run a report from another survey based on the same Feature Service successfully, so I'm really not sure what the issue is.
Another Issue is I am unable to generate more than 200 individual Feature Reports at a time.
SindiswaMsubo
Hi!
@ZacharySutherby Please can you kindly assist, It is really urgent.
MatthewN
Was there any resolution to this issue? I am having the same problem.
MargaretMacKrell
Was there a solve to this? I am having the same issues. The docx will work and then when I try to preview another I get the below message.
FirouzehBroumandi1
I have the same issue since yesterday. anyone has answer to it?
Thank you
MargaretMacKrell
I sent my word document into ESRI support and they showed me that you need to input additional code to end repeats/nesting info.
SLUBrookeJohnson
what additional code did they show you to end repeats?
RENDANIMUDAU
Good day,
would you please share the solution to the problem if you managed to solve it?
