Geopoint map visible on form by default
1787
09-19-2023 09:25 AM
doronwen
ArcGIS Survey 123 Version 3.18.123
I'd like the users to see the Geopoint map window visible by default, when they first open the form.
At the moment, when users open the form they need to click the little map sign to open the map.
Is there any option to set that visibility by default in Survey 123 Connect?
Edit: I know that once you select a point on the Geopoint map, then the map element stays visible in the from. I just want the map to be visible without interaction from the user.
ZacharySutherby
Hello @doronwen
The only way to display the map on form load (without location services enabled) is to set a value in the default column of the XLSForm.
Thank you,
Zach
ZacharySutherby
Hello @doronwen
Thank you,
Zach
doronwen
@ZacharySutherby thanks. the users of this toll will have the location turn on at all times. and it appears that when the location is on, the map element show up by default. That's what I was looking for.
