Formatting the results of nested repeat in a survey report
951
10-29-2022 10:41 AM
GISPro1
I am trying to display the results of a nested repeat in a report, but I need the results grouped by one of the repeats.
For example, instead of:
I need the results to be formatted like:
Thank you for the assistance!
Katie_Clark
Could you provide your XLS form so I can see how the schema is structured? I'll try to help...
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
GISPro1
Thank you for taking a look, Katherine
