First page of repeat blank on edit
1317
05-12-2022 07:43 AM
MelissaKimble
I have a survey that has been working fine up until the most recent Survey123 update. When editing a record from the inbox, the first page of a repeat is blank (s123_v3_14_255_iphone.png, s123_v3_14_255_android.jpg). All pages after the first page populate with content - so it's only the first page that's affected. With older versions of Survey123 (e.g., v3.9.149, s123_v3_9_149_windows64.png), all repeats populate with no issues. I tried finding downloads to the older versions of Survey123 for windows, but they seem to be unavailable. So it seems I'm stuck trying to troubleshoot this issue. I've tried moving the 'query' parameter from the beginning/end of "allowUpdates=true". One post recommended adding "query=1=1", which I had no success with. The survey we use is also attached (example_survey.xlsx). Any suggestions/feedback would be greatly appreciated!
Thank you!
Tags (3)
AnnelieseMyers
Did you ever find a solution to that issue? I'm running into that with only one field in my survey.
BryanWright
I just had the exact same thing happening but the solution in this post seemed to resolve it.
