File not found : function.js - Getting this error after while testing the published Survey
1200
01-24-2024 10:23 AM
pramodmandali
I have created pulldata function to pass the parameter to my custom javascript function and it is working file when I test the changes in Survey 123 connect but while testing the survey, getting file not  found function.js error.
DianaTorres10
Are you logged in?  Can't use JS if anonymous user.
The following are known limitations when using JavaScript functions in survey forms:
  • Document Object Model (DOM) is not supported.
  • Frameworks such as JQuery, Ember, and Angular are not supported.
  • You cannot access local files.
  • Asynchronous calls are not supported.
  • JavaScript functions are only supported in forms completed by users in the same organization as the form author.
  • JavaScript functions are not supported for public surveys.
  • A pulldata("@javascript") function cannot be called inside a pulldata("@json") function on the Survey123 web app.
https://doc.arcgis.com/en/survey123/desktop/create-surveys/pulldatajavascript.htm
