Feature reports not working
2209
6
02-27-2024 11:24 PM
RENDANIMUDAU
 Good day,
I have published my survey on ArcGIS Online and when trying to generate the reports from survey123 website, the error message below appears, I used connect version 3.18.123
An error occurred when rendering by the report engine. Failed to print map for ${shapes}. Failed to load web map: c5b4c074bbda4cbc81719f1f42134fb7. Invalid URL: https://services1.arcgis.com/aiigQkyAFLnUvOAp/arcgis/rest/services/service_3bad31d4de034a15a97cbf545....
alyssajhnsn
I have this issue happen a lot. Is there a repeat in the survey?
TylerGraham2
Can you share your report template or just the relevant portion with us?
RENDANIMUDAU
Good day,
I am using the default template
Regards
WilliamBernis
I have a form, when I want to see the data, it only loads in the second tab but nothing appears in the first. What could be happening?
abureaux
MVP Frequent Contributor
The map's ID (c5b4c074bbda4cbc81719f1f42134fb7) isn't valid.
Can you locate that id on your Portal?
Also, can you toss in a different ID (e.g., b834a68d7a484c5fb473d4ba90d35e71) and does it work?
alyssajhnsn
RENDANIMUDAU
Good day,
Yes, there is a repeat question in the survey as well as a pull data question from the web service.
