Feature Reports | As of 9/6 I can't filter to the related table AND...
523
09-06-2022 09:49 AM
MichelleWilliamsERM
I hope this WAS a programming mistake and not a permanent change.
I've always been able to filter to fields in the related table, and now I'm forced to filter to the parent; if this is a permanent feature that means I'll need to calculate the fields I need into the parent, for this one survey that could be 12 new fields in the parent. Please HELP quickly; I have reports I need to run.
AND the Post2Stabalize is linked to the wrong area, it should let me type in Starts with...
@JamesTedrick
MichelleWilliamsERM
Thank you, Esri, you quickly fixed this issue.
MichelleWilliamsERM
I thought I'd try this again to see if I could get it to work.
I could get it to work, but it's not very friendly.
After many extra clicks and some long scrolls, I was able to get it to work.
@Esri, it was nicer when I could type in the field name instead of scrolling 100 fields. You are tightening the reigns on how this is done, and it takes more time to do it this new way. I hope you find this note helpful.
MichelleWilliamsERM
