I am trying to use open Survey 123 from Collector in order to update a related table in a feature service. I have been following the steps in this article: How To: Populate a related table from a Survey123 for ArcGIS feature service for Collector for ArcGI...
I am able to open Survey 123 from ArcGIS Collector and add a record in the related table. The problem I'm having is that the record added to the related table does not populate the GUID field in the related table (see image below)
This is an image of the XLSX sheet in Survey 123 showing the type, name, label and field type for the GUID field in the related table
This is the URL passed to the popup in Collector to open Survey 123 from Collector:
arcgis-survey123://?itemID=9c24cd21569440f8b442d412781144fe&field:ParentGlobalID=[HYDGUID]
The record is added to the related table but the GUID is not populated. Attachments are also added but are not linked to the feature layer.
I'm not sure what I'm missing that will allow me to add the GUID to the related table and have the related record linked to the parent feature. I am able to successfully link the two tables and populate the GUID field in Collector when NOT linking to Survey 123.
Supports ApplyEdits with GlobalIDs is true in the feature service.
George Hilton
