Error in Survey not showing table-list choices
2094
6
11-30-2021 05:56 PM
Felicitychun
The choices are no longer showing in the app for a table-list appearance. This app version is 3.13.244
this is in version 3.12.274
Can this be fixed easily with different people and devices using this?
by Anonymous User
Not applicable
Hi @Felicitychun,
Thanks for sharing your XLSForm. I can confirm this issue has already been logged as BUG-000144253. I would suggest raising this issue with your local Esri Support and having them attach your account to the case, so you can track the progress.
This issue only occurs when you first open the survey or first make the table-list question relevant. If you collapse and expand the group or repeat that the table list questions are inside, or you make the group not relevant and then relevant again, you will see the labels displayed. You can do this in your survey by making the "Was MH located?" toggle between yes, no and yes, and then the group "External Inspection" will change relevance, so the labels then display. Or just collapse and expand that group.
Regards,
Phil.
Felicitychun
@JamesTedrick @Anonymous User
by Anonymous User
Not applicable
Hi @Felicitychun,
Can you please share your XLSForm and any media folder files, so we can take a closer look at how the form is configured?
Regards,
Phil.
Felicitychun
Hi Phil,
I have attached my XLSForm there are no media files. As mentioned it was appearing in 3.12 but then not in 3.13 when the app was updated.
Thanks
by Anonymous User
Not applicable
Hi @Felicitychun,
Regards,
Phil.
DeonLengton
Do we have an estimate when this bug will be fixed? From the bug report it seems this bug hasn't even been prioritized to be fixed yet?
by Anonymous User
Not applicable
Hi @DeonLengton,
We have this issue in our backlog, however are currently working on wrapping up 3.14 release as it is close to RC stage now. The fix for above issue will likely be included in a future update after the initial 3.14 release.
Regards,
Phil.
