Editing existing information in an ArcGis repository
430
07-27-2023 01:04 PM
kmorenoz
Hello, good afternoon. 👋
Hope you are well.
I have a doubt, I have created a form in Survey123, the form has 4 fields to fill, I decide to fill only 3 of the 4 fields in real time since I do not have in number 4, I send the data and these are stored in the ArcGis repository, if I want to later update the data sent to add information to the last missing field that I did not fill at the time because I did not have it, how would it be done? Keeping in mind that I would update it as a normal user and not from the Survey administration panel.
DougBrowning
123 just adds data to a regular AGOL hosted service.  So you can update this in any AGOL web map or Pro.  You can even now update it right from Excel using the new ArcGIS for Excel extension (editing is brand new).  This is slick if you want to work your way down the list.
Hope that helps
