Dynamically setting initial geoshape map extent by referencing previous answer?
177
3 weeks ago
RayKidd
New Contributor III
Hi everyone, two questions:
1) Is it possible to dynamically set the initial map extent for a geoshape question by referencing a previous answer? Searching the forum suggests not, but most answers are old.
2) If so, is it possible to do this within a repeat, such that the geoshape in repeat N defaults to the location selected in repeat N-1? This would make it a lot easier to draw multiple polygons that are close to each other, rather than starting from scratch each time.
Thank you!
abureaux
MVP Regular Contributor
"Is it possible to dynamically set the initial map extent for a geoshape question by referencing a previous answer?"
No. These are static in Connect.
DougBrowning
MVP Esteemed Contributor
One idea is in each repeat add a field to grab the lat and long using pulldata.
Then in the default (or maybe calculation) for the geopoint use indexed-repeat(question, repeat, index number) to grab those lat/long fields.
That may work
abureaux
RayKidd
New Contributor III
Thank you for confirming.
