Do not require user to click refresh button when field is hidden
2038
05-14-2021 12:06 PM
JoseVidal
When using the Inbox feature and the 'calculation' column to calculate values, sometimes those calculated values are not now shown. Instead the user sees a recycling icon. When the user presses it then the value gets calculated.
This works OK, until that field is 'hidden' and its value is used by yet another 'calculation'. In these cases the final value cannot be calculated because there is no recycle button to press.
abureaux
MVP Frequent Contributor
Thanks for the reply.
The thing that jumps out to me is the use of text fields for calculations. Have you considered using a combination of [type] note and calculate? See below:
typenamelabelcalculation
textnameName
decimalinputEnter a number
calculatedouble_input ${input}*2
note Double of it: ${double_input}
calculateyes_no_calc if(selected(${yes_no},'yes'), ${input} * 50, 0)
select_one yes_noyes_noYes or No
notegrade${yes_no_calc}
calculatedouble_grade ${yes_no_calc}*2
note Double of above = ${double_grade}
abureaux
I am likely not understanding what you are doing. Looks like you are using text fields, so I am not sure where your output is supposed to be. And sounds like you are using hidden fields for calculates?
Why not use a [type] calculate field? They are hidden by default. May help if you share your example doc.
JoseVidal
I am using the calculation column to do some calculations. The above image is from the spreadsheet:
textnameName
decimaldouble_inputDouble of it${input}*2
decimalgradeinput * yes_no(yes = 50, else = 0)if(selected(${yes_no}, 'yes'), ${input} * 50, 0)
decimaldouble_gradeDouble of above${grade}*2
The process is complicated:
To reproduce the problem you have to connect both TCSubmitter and TCReviewer to the TC Service. Turn on the Inbox for the TCReviewer. Then submit a TCSubmitter form with the number field empty. Then go to the Inbox of TCReviewer to see the submitted form.
The TCReviewer will show the "reload" icon above on that one field (see image above).
But, if I make that field hidden then the final field (double of the above) does not get the reload icon and does not get a value either.
abureaux
textnameName
JoseVidal
You might say "just don't make the 'grade' field a 'hidden' field and the user will press the reload button".
The thing is, this is just a reproduction of the real spreadsheet, which has hundreds of values and dozens of intermediary values. 'grade' is an example of an intermediary value. We would like it to be hidden, but its value automatically calculated so that other calculations which depend on the value of 'grade' will also get calculated.
JoseVidal
Yes, thanks!
Making the intermediary values  of type 'calculate' and the final values of type 'note' makes it work.
