display the field if the value is not empty
1289
02-09-2022 09:46 AM
GregoireCatineau
I would like to display the field value if a value exist in this; on the same line...
typenamelabelhintrelevant
textC22_ZTI Zone Touristique Internationale${C22_ZTI}!=''
I recieve this error message:
b'ODK Validate Errors:\n>> Something broke the parser. See above for a hint.\nDependency cycles amongst the xpath expressions in relevant/calculate\n\nResult: Invalid'
AndyMcClary
Your issue is that you are referencing the value of the field in its own relevant expression, creating a loop. You need to base the relevant expression off a different field's value.
AndyMcClary
GregoireCatineau
Thanks you for your response. I think we can't use the same name field on the same Excel sheet.
