Did the Aerial Hybrid option for a basemap in Survey123 connect get removed?
448
02-12-2020 08:05 AM
ShelleySchulte1
New Contributor III
Did the Aerial Hybrid option for a basemap in Survey123 connect get removed? I swear this was there a few months ago.
JamesTedrick
Esri Esteemed Contributor
Hi Shelley,
The Aerial hybrid has not been an option for Survey123 Connect - the current map option only supports 1 layer basemaps (Aerial hybrid is 2 layers - the imagery and the labels are separate services).
ShelleySchulte1
New Contributor III
Thank you, James!
ZacharyVavra
New Contributor III
Hi James,
I created a survey in Survey123 Connect and would like to have the Imagery Hybrid basemap display as the default basemap when a geopoint field question appears. I don't want the end user to have to change the basemap in the  Map Gallery. Is there a work around to achieve this?
Zach
