I am building a dashboard to display the survey information. I use a date selector in the dashboard to filter to the most recent survey completed. However, the dashboard is not picking up the data in the survey map layer. The first image below is a screenshot showing the data from the map layer. It shows the current date and time of the last survey completed.
The second image is what the dashboard is displaying when I use the date selector to filter to the most current date survey.
I am using the new map viewer and the new dashboard. I didn't have this issue previously when using the classic version of both. Has anyone else run into this issue or have any idea why it wouldn't be filtering.
@Andrew_H I ended up just rebuilding the whole thing. I moved quite a bit of it into Experience Builder when I set up our new hub site.
