Crossed image icon, unable to take a picture
1026
07-01-2024 04:37 AM
corete_potagere
Hi community,
I'm having troubles with my survey form. In some cases, a crossed image icon appears instead of the camera icon. The button used to work fine, I don't know exactly what changed since.
Any ideas why?
Many thanks
DougBrowning
MVP Esteemed Contributor
corete_potagere
I just received this screenshot from a field user. In his case, the button works for the first image but not for the following ones. Other users with the same form version do not experience this issue. They are all using the same devices.
jcarlson
That icon appears when a photo question is read-only, could that be the case? Are your users adding new features, or editing existing ones?
- Josh Carlson
Kendall County GIS
corete_potagere
Hi Josh, thanks for your reply. The questions are actually not marked as read-only. And the users are both editing and adding new features. The only parameters for the questions are :
body::esri::style method=camera, and bind::esri::parameters fileName=concat(${building_id_calc},"_front") fileNameVisible=true allowRename=false
DougBrowning
corete_potagere
It does seem to be the same issue.. Thanks for the heads-up, Doug
