Hello Everyone,
I would like to be able to have one survey for multiple existing features. I have a parcel layer and there will be times when a landowner has two or more parcels, when a survey is created it would need link to each of those existing features.
Thank you in advance!
If you have a relationship already that links the two, you could use a repeat for the parcels.
That is what I did, but when I go to publish it says the table isn't found.
One thing to check is the name of the repeat must match the name of your table.
If the relates do not work, since parcel data may not always be live data you could work off of a save/copy where same owners are joined into a single parcel polygon for your purposes. Granted I am not sure how easy this is with your workflow but it is an option. Hope it helps!
