Creating one survey for multiple locations
851
07-07-2021 06:21 AM
ZGutknecht
Hello Everyone,
I would like to be able to have one survey for multiple existing features.  I have a parcel layer and there will be times when a landowner has two or more parcels, when a survey is created it would need link to each of those existing features.
Thank you in advance!
Nick_Apostolakis
If you have a relationship already that links the two, you could use a repeat for the parcels.
ZGutknecht
That is what I did, but when I go to publish it says the table isn't found.
Nick_Apostolakis
One thing to check is the name of the repeat must match the name of your table.
GIS_Fox
If the relates do not work, since parcel data may not always be live data you could work off of a save/copy where same owners are joined into a single parcel polygon for your purposes. Granted I am not sure how easy this is with your workflow but it is an option. Hope it helps!
Jansen Lyons - Records and GIS Section - Public Works - City of Rio Rancho, NM
