Creating a copy/duplicate of an existing survey entry, editing it and saving as a new survey entry through experience builder
1366
12-12-2023 01:23 PM
PankajBajracharya
Hi All,
I am trying to create a copy of/duplicate an existing survey entry associated with a polygon feature , edit it and send/save it as a new survey entry all done survey123 connect within the experience builder.
I was wondering if there is a work around for this particular issue.
I know you are able to Submit a new record and Edit an existing record in Survey123 using experience builder - but I am looking for a way to be able to select a record and instead of "Edit an existing record"  make a copy of it and submit it. Which would in turn create a new record.
The goal is to have an archive of previous edits that were made associated with that particular polygon feature.
The link below is the closest that I found to what I am looking for but not exactly
https://community.esri.com/t5/arcgis-survey123-questions/method-to-to-copy-data-from-an-existing-sur...
@JamesTedrick
@JodyZhengLiu
Any help is much appreciated.
Best Regards,
PK
