Method to to copy data from an existing survey record into a new record for updates/edits?
8111
10
11-30-2020 11:41 AM
KimberlyMcCallum
I am looking for a way to create a new Survey123 record that is prepopulated with data from an existing record. Ideally, I would like to have a Dashboard where a user selects an existing record from a list or a map and that initiates a new record with the values from the existing survey copied into all the fields, allowing them to update and add to this data in a new record. Following these two posts (https://community.esri.com/t5/arcgis-survey123-questions/duplicating-survey-editing-records-in-a-web... and https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-editing-records-in...), I was under the impression that I could do this just by using the URL parameters and simply omitting the mode parameter; however, when I try to open a survey without specifying mode=edit OR mode=view (e.g., link below), I get the following error: "Cannot read property 'view' of undefined"
https://survey123.arcgis.com/share/db2d5d3e245d40ce9b53239015a01cfc?globalId=4af34610-79b0-43fc-8bb7...
(if I add mode=edit or mode=view to the URL, it works but those don't meet my needs of copying the data into a new record).
Am I missing something? Or, is there a better approach that I should be taking to accomplish this workflow?
Thanks in advance for any and all feedback.
JodyZhengLiu
Hi @KimberlyMcCallum ,
This is in production already🙂
Jody Zheng Liu
JodyZhengLiu
We will support a new mode: ?mode=copy&globalId=<existing_record_globalId> in the web form in mid-December update, which will copy the data from an existing record into a new survey. Could you please have a try then?
Jody Zheng Liu
KimberlyMcCallum
Thanks @JodyZhengLiu for the prompt reply! That is good news for me but can you provide any more detail on when this feature will be released and how I will know when it's out?
Best,
Kim
KimberlyMcCallum
I found that the mode=copy parameter has been implemented and works well for me on the Survey123 beta site:
https://survey123beta.arcgis.com/
I hope this gets into production soon!
JodyZhengLiu
Jody Zheng Liu
srikanthnamburi3
Hello, Is this working now? any example where i can test it out or a detailed document i can refer to. Looking for your response.
KimberlyMcCallum
This is working now! I am using it in my workflows but I guess you will have to setup your own test data to see it in action. Publish a survey, add a feature to it, go copy the global id and copy it using the URL parameters and your data:
https://survey123.arcgis.com/share/<very-long-unique-survey-id>?mode=copy&globalId=<very-long-global...
Good luck!
srikanthnamburi3
Thank you
JeffHyder
I am trying something like this as well but am struggling with getting the data to pass to the new survey. How is it done? Do I put this url some where in the new survey as answers to the questions. I appreciate any and all help. Thank you.
ZachStern
@JodyZhengLiu I'm also unsure how to pass the data along from the original survey to the duplicate while the user is completing the original survey. What is the workflow for this?
Thanks!
