Copy existing data from a previous repeat table on to the next one
923
12-13-2024 06:56 AM
neomapper
Is there a way to copy existing data from a previous repeat table on to the next one inside survey123 form? The goal is to have the user open an existing point from the inbox, click for a new repeat and cross all the data from the previous recorded record. Any examples or direction would be great. Thanks
abureaux
MVP Frequent Contributor
Not directly.
Here is one possible method. This is dependent upon data types.
Here is a slightly different take on it using indexed-repeat. You can probably use a Script to do this and add the data into the repeat (indexed-repeat on its own will result in a circular reference).
