Coordinate System for Survey123
636
12-16-2025 01:16 PM
RachelWhittington
Hello all!
I am wondering if anyone knows what the coordinate system is used in Survey123. I have found through research that the datum is WSG84, but I haven't found anything for the coordinate system. Does anyone know what the general system is used for Survey123 or where one could find that information? Thank you!
abureaux
MVP Frequent Contributor
As you already mentioned, and as Ismael and James confirmed in the two posts @Neal_t_k  linked, S123 uses WSG84.
If you are interested in other system though, please see Working with USNG and MGRS in Survey123 for ArcGIS
There are also some Samples built right into Connect. For example, these few:
