I know this one has been covered a lot and Ive been trying to get a calculation from a previous answer to work but so far it just gives me an empty field.
now()+pulldata("@property", "utcoffset")*1000*60*60
I'm trying to create a hidden field from Survey 123 Connect that when I open the Feature Layer in Pro will have the converted DateTime field showing my local time etc when the survey result was captured.
So far it just turns up blank o matter what I try??
Hi. Try the following:
If you want to hide your calculated value, apply the hidden appearance to your question. Do not use the hidden question type, use the hidden appearance instead.
Thanks for your reply @IsmaelChivite
I followed the steps you provided above and it all looks good in the survey but once the survey is submitted and I access the Feature Layer either in AGOL or in ArcPro the "My date plus offset" field is empty. Thanks
Have you had a similar issue as my response? when getting the survey results in Pro or AGOL?
