Conditional (if / then / else) logic in Survey123 using numeric answers
42887
15
03-19-2021 12:40 PM
SilverwoodConsulting
Hi there,
I'm trying to use conditional if / then / else logic in Survey123 to take a range of numeric values calculated in (question_one) and assign it a value accordingly.
I've tried modifying this script (from: https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformformulas.htm#ESRI_SECTION2_BED1A39...😞
if(condition, a, b)
If the condition evaluates to true, returns a; otherwise, returns b.
if(selected(${question_one}, 'yes') and selected(${question_two}, 'yes'), 'yes', 'no')
The conditional logic would be something like:
            if(${question_one} > 1.0 and < 1.9) then assigned_value = '500mm'
            if(${question_one} > 2.0 and < 2.9) then assigned_value = '600mm'
            else(${question_one} > 2.0 and < 2.9) then assigned_value = '700mm'
I've tried this format (and similar variations):
            if(${Q100} > 0.5), '500'
Note: question_one is a numeric field (decimal) that calculates a total based on other fields in the form (i.e. an average). The assigned_value field would then use that auto-calculated numeric value field and categorize the numeric values based on ranges (i.e. 1.0 to 2.9 or >= 1 and <= 2.9).
Is this possible within Survey123. Does anyone have experience using a similar loop conditional statement?
Thanks in advance for your help!
SJ
DougBrowning
MVP Esteemed Contributor
You are just having some syntax issues.
First you always need to build both sides of an And or Or.
if(${question_one} > 1.0 and ${question_one} < 1.9, '500mm', 'no')
123 does not have esleif so it does get harder to chain them together.  But it goes like this
if(${question_one} > 1.0 and ${question_one} < 1.9, '500mm', if(${question_one} > 2.0 and ${question_one} < 2.9, '600mm', if(${question_one} > 2.0 and ${question_one} < 2.9, '700mm', 'none of the above')))
So same logic, it just needs to be written on all one line. if(condition, true, false)  Hope that helps.
DougBrowning
Thank you! This worked out perfect! 🙂
ChristopherMask
Hello Doug,
I wanted to see if you could help on this?
if((${ResourceType}="Personnel", ${HourlyCost}, " "), if(${ResourceType}="Equipment", ${OthersCost}, " "))
ChristopherMask
I used this and it worked
coalesce(${HourlyCost},${OthersCost})
ChristopherMask
Good Morning Doug,
Wondered if you would give this a quick look.
The name columns Two09 and Two09Calc. It currently has this for the calculation:
if((${FinalFireAcreQuantity}>=300 and $NumberFatalities} >=1), 'Yes','No')
If statement is true, then Two09 = Yes, if not Two09 = No.
DougBrowning
You are missing a { ${NumberFatalities}  see in bold
if((${FinalFireAcreQuantity}>=300 and ${NumberFatalities} >=1), 'Yes','No')
ChristopherMask
Goodness, that worked! Thanks for the response and have an excellent weekend!
Also, change to an or statement. if((${FinalFireAcreQuantity}>=300 or ${NumberFatalities} >=1), 'Yes','No')
Christopher
AmandaBeck
I'm hoping you can help me out with this one.
I want to have a conditional statement after a geopoint question is completed.
If you select within a parcel, then you are within the boundary. If you select outside of a parcel, you are outside the boundary.
Any help is appreciated. Thanks!
