Conditional (if / then / else) logic in Survey123 using numeric answers
37340
15
03-19-2021 12:40 PM
SilverwoodConsulting
Hi there,
I'm trying to use conditional if / then / else logic in Survey123 to take a range of numeric values calculated in (question_one) and assign it a value accordingly.
I've tried modifying this script (from: https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformformulas.htm#ESRI_SECTION2_BED1A39...😞
if(condition, a, b)
If the condition evaluates to true, returns a; otherwise, returns b.
if(selected(${question_one}, 'yes') and selected(${question_two}, 'yes'), 'yes', 'no')
The conditional logic would be something like:
            if(${question_one} > 1.0 and < 1.9) then assigned_value = '500mm'
            if(${question_one} > 2.0 and < 2.9) then assigned_value = '600mm'
            else(${question_one} > 2.0 and < 2.9) then assigned_value = '700mm'
I've tried this format (and similar variations):
            if(${Q100} > 0.5), '500'
Note: question_one is a numeric field (decimal) that calculates a total based on other fields in the form (i.e. an average). The assigned_value field would then use that auto-calculated numeric value field and categorize the numeric values based on ranges (i.e. 1.0 to 2.9 or >= 1 and <= 2.9).
Is this possible within Survey123. Does anyone have experience using a similar loop conditional statement?
Thanks in advance for your help!
SJ
EduMoldovaAdmin
Dear colleagues,
I am struggling with very simple question. Please help to sort i out. I have a string quesion {crop} with dropdown and one choice should be selected. Have another string quesion {alt_crop} to polulate based one choice from {crop}.
Struggling with syntaxis here (not working):
if(selected(${crop},'Corn'), 'Winter wheat', if(selected(${crop},'Winter wheat'), 'Sunflower', 'na'))
Survey is done based on existing layer ({crop} haas domains
what is wrong here?
RobertAnderson3
MVP Regular Contributor
What is happening when you try to save/run the calculation? The first thing that comes to mind is use the domain values, not the display names as I was encountering this earlier with a colleague.
BryceHancock
I am trying to evaluate 2 if statements in the calculate field of an xls form and the following works for the 1st statement but not the 2nd (the 2nd statement is in bold):
if(selected(${RMZ_CLASS}, 'CAT_1') or selected(${RMZ_CLASS}, 'CAT_2') or selected(${RMZ_CLASS}, 'CAT_3'), ('100 Feet'), '0 Feet' or if(selected(${RMZ_CLASS},'CAT_4'),('50 Feet'),'0 Feet'))
When I choose CAT_1, 2, or 3 in the list '100 Feet' is returned in the field, but if I choose CAT_4, '0 Feet' is returned, when it should return '50 Feet'.
Anyone have ideas where I am going wrong?
DougBrowning
MVP Esteemed Contributor
You have 2 else statements and too many parenes try this
if(selected(${RMZ_CLASS}, 'CAT_1') or selected(${RMZ_CLASS}, 'CAT_2') or selected(${RMZ_CLASS}, 'CAT_3'), ‘100 Feet', if(selected(${RMZ_CLASS},'CAT_4'),'50 Feet','0 Feet'))
TKSHEP
@DougBrowning I am trying to also do something similar, however with months in a year. I am trying to use a conditional calculation to autofill the fiscal year.  I have this,
format-date(${inspection_date}, '%n'), if(${inspection_date } =< 1 and ${ inspection_date } =>3, 'Q2', and if(${inspection_date}=1 or 2 or 3, 'Q2') and if(${inspection_date}=4 or 5 or 6, 'Q3', 'Q4'))
  however I am getting an error and was wondering if you could help me with it.
Thank you so much for your help.
DougBrowning
Do you have this all in one field or something?  If so that is not the correct way, this statement above just has a function at the front.  Also all of your syntax is incorrect.
You need to split this to 2 fields.
Field_1 is format-date(${inspection_date}, '%n')  note set to integer type and appearance as hidden.  Set bind::type to null if you do not want this field in the final schema.
Then Field_2 uses the value from Field_1
Easier to read this way and proper syntax
if(${Field_1} <= 3, 'Q1', if(${Field_1} >= 4 and ${Field_1} <= 6, 'Q2', if(${Field_1} >= 7 and ${Field_1} <= 9 'Q3', 'Q4')))
Would be a good idea to read up on how if statements work in general.  if(condition, true, false)
