Color a Calculated field based on result
498
06-08-2020 07:21 PM
GordonSumerling
I have a calculated field in my survey123 form. The various inputs from other questions derive the total value in this field.
I want to be able to colour the field in the form if it below, between or above values. For example
Calculated Below 5 = green
Calculated between 5 & 9  = orange
Calculated above 10 = red
How can this be achieved in the survey form?
Tags (1)
DougBrowning
MVP Esteemed Contributor
Have 3 note fields with html for each color.  Then use relevant to show the correct one while the others are hidden.
Hope that helps.
