choice_select
1276
05-30-2020 03:36 PM
CharlotteSmith4
How do you set up "Choices" when you have non-unique names? Please see attached.
JamesTedrick
Esri Esteemed Contributor
Hi Charlotte,
Apologies for the delay in response.  Generally, choices should be unique.  In your example, you have 3 attributes:
- State
- City
- Neighborhood
You should create a unique string to represent each neighborhood; one way to do that would be to give each city a unique value and add the neighborhood name (say, MA_Boston_A).
Given the relationships between state, city and neighborhood, you may also want to consider using cascading selects to make it easier to filter the choices - see Cascading and external selects—Survey123 for ArcGIS | Documentation  and Cascading Selects and External Selects
