Can bind esri parameters be used to Allow Null values to False?
776
06-01-2020 10:51 AM
DougBrowning
MVP Esteemed Contributor
I have a simple form that can also be used in Collector.  I was to set fields to required - which means set Allow Null values to false.
I tried just required=yes hoping 123 set the property on the service but it did not.
So next I was hoping I could use bind::esri::parameters for this.  I cannot find any doc on it though.  Is this possible?  Syntax?
I tried using AGOL also but, while I can see the property, I cannot seem to change it.  I would have to over publish from Pro or Map maybe?
My end goal is snapping or tracing over the top of existing features (NHD lines).  I tried using Linked content map but no features ever show up in it.  I found a post that said wait for it but still nothing.  I am leaning towards Collector for the snapping which 123 does not have.  Collector does not seem to snap very well however.
JamesTedrick
Esri Esteemed Contributor
Hi Doug,
Apologies for the delay in response.  You are correct, setting required=yes will not turn off the 'Allow null values' field option.  You would need to publish from ArcGIS Pro if you have a requirement for non-null at the database level.
