Choice filter not working in Survey123 Connect
1989
8
12-12-2023 02:27 PM
ScottPool
New Contributor II
Hi there,
For some reason I can't get the choice_filter functionality to work. I followed the exact steps in this guide (Survey123 Tricks of the Trade: Choice Filters - Esri Community) but it doesn't seem to work for me. No choices appear in the Regions question when I select a country.
Anyone know what the issue might be? I've attached photos to show exactly what I've done and what's happening. I've copied the exact example from the guide above too.
The only fields filled in for the "region" question is type, name, label, and choice_filter. Every other field is empty.
I also replaced 'selected(${country}, country)' with 'country=${country}' in the choice filter and it worked fine but I need the region question to be multiple choice and the latter expression doesn't work for multiple choice questions.
2 Solutions
ChristopherCounsell
MVP Regular Contributor
what version of Survey123 Connect?
Does this happen with the choice filters sample survey or just your XLSForm? If the latter, can you share it?
abureaux
MVP Frequent Contributor
3.10.239? That is VERY out of date. 3.19 is the current version. You will want to start by updating Connect. I'd suggest doing so from the Microsoft Store if you can, since that will auto-update for you.
ChristopherCounsell
ScottPool
New Contributor II
Hi, my Survey123 Connect version is 3.10.239 (updating fixed the issue).
The problem occurred in all of my surveys where I tried to implement it. However, I was only testing it in the Form Preview within Survey123 Connect (where it never worked). I just re-published a survey with the choice filters added and it works as expected in the published version. It still doesn't work in the Form Preview in Survey123 Connect though.
So, it seems the problem is that the choice filters using the above methods don't work in the Form Previews for any of my surveys, but they work in the published versions.
Updating to the latest version seems to have fixed it!
Thanks!
abureaux
ScottPool
New Contributor II
And yep, I tried the sample survey and the same problem I was having was still occurring.
abureaux
 Have you tried putting quotes around the text?
selected(${country}, 'country')
ScottPool
New Contributor II
Yep, have tried that and that didn't work either
abureaux
Have you tried theCascading Selects example built into S123? If that doesn't work, it is definitely a software issue as @ChristopherCounsell stated.
I have attached a simplified XLSX with a working choice_filter (using two different formats).
ScottPool
New Contributor II
Yep, have just used the built in "Choice Filters and Cascading Selects" sample and the choice lists still don't appear in the Form Preview where the 'selected(${question}, column)' choice filter method was used, as was happening in my surveys too.
Edit: Updating to the latest version fixed the issue!
