Change Note Font Size and Color
7179
04-13-2022 01:09 PM
michael_vetter
I have a note in my survey and I was wanting to change both the size and the color of the text. I see from the documentation that this is possible, but how would I format it so that I can control both the size and the color?
Currently, I'm using if(${field} = "Yes",'<font size="5"><font color="blue">The address IS within the city limits.</font></font>','<font size="5"><font color="red">The address IS NOT within the city limits.</font></font>')
The if statement works, but if I change the font size to anything other than 5, then the font size goes back to the default size.
Thanks for any help!
michael_vetter
I was just wanting the font size to be big enough so that the note catches the eye of the user and that the user will actually read the note.
Edit:
I came across this blog about using HTML tags and I decided to go a different direction than initially planned. I decided to use a DIV element in the label and everything is working as expected now. Thanks for taking a look at this for me!
Katie_Clark
MVP Regular Contributor
I haven't been able to reproduce the issue with some quick testing - ideally, what would you want the font sizes to be for each scenario?
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
michael_vetter
Edit:
Katie_Clark
Oh, good to know! Glad you got it all worked out 🙂
Best,
Katie
