cant see the response but if expire to excel all information there
694
12-22-2022 12:12 PM
DrJumaKhudonazarov
I  have published a new survey  and when sublet response I can see them on data section it is blank . if export to excel all data available  what am I doing wrong?
Tags (1)
Richard_Purkis
@DrJumaKhudonazarov  I am unable to recreate this error.
To help isolate the issue, may you publish a test duplicate survey and confirm if the issue still occurs.
If it does, may you confirm if you are using the web designer or Survey123 Connect?
Thanks
Richard_Purkis
Thanks
DrJumaKhudonazarov
Thanks  sorted out  it was the day when survey123 behaved strangely  published it next day all worked  well
