Update Attribute Schema in Make/Integromat to Include New Fields
1973
05-12-2022 05:11 AM
Andrew-Bowne
I have added a few new fields to my feature layer and would like to include them in my automations.  I am using Make/Integromat.  How do I update the schema in Make/Integromat to recognize these new fields?  I have done this before but for the life of me, I can't remember how I did it.  Is there somewhere that I can simply "Refresh Schema"?
Tim-Woodfield
Did you ever find the answer to this? @IsmaelChivite do you know the best way to do this?
Tim-Woodfield
I just wanted to follow up if anyone else came across this post. I submitted a help ticket to Make and got a response. Click on your Survey123 module to open it and click the 3 vertical dot button in the top right. There should be a "Refresh form" option. Click OK on the module settings and a bubble should pop up saying Refreshing metadata. The fields should now show up in other modules under feature > attributes.
Danielle_Kuchler
Three years later, I just wanted to confirm this worked for me!
