cannot read properties of null (reading '0')
3711
03-31-2022 06:34 PM
SFM_MickieSmith
After I saved an older survey V3.13 as another survey V3.14, published the survey and launched the survey in the browser, I get the "cannot read properties of null (reading '0') error".  Based on the comments regarding this error,  I cleared my browser cache and removed a blank line in the CVS file.  I still get the error. Some of the special characters in the file consists of  ( ) or / . I did not experience any problems with these special characters in the previous survey versions. When I reviewed the file in the Notepad... it showed some of the information with a # sign but it is not in the CVS file from what I can tell. The survey references three CVS files... I attached one of the files for your review.  I hope this helps.
The survey123 connect version is 3.14. Both surveys are still using the V3.13 template version.
Do you have any suggestions on how I can fix this issue?
ZachBodenner
MVP Regular Contributor
Hi, did you ever find a solution to this? I am running into the same problem and I've done all the same troubleshooting steps. I have worked it down to possibly being my pulldata functions. I have three calculations that pull data from a feature service - when I remove them from the xls then it will not show the  "cannot read properties of null (reading '0')" error.
Happy mapping,
- Zach
JaredPilbeam2
Have you tried setting the survey to the latest version (i.e. under Settings in S123 online)?  I would read Notes, first.
I created a survey from scratch and changed some fields to nothing unordinary. At first, I thought maybe the Excel warning (below) was causing the error in the console. But, then I set my survey to always use the latest version and the console error went away.
