Can i pre populate a degree symbol (for temperature) into a text type that cant be removed by the end user on a device?
1165
04-23-2020 12:47 AM
TomGillespie
I have used the default column but i want it to be fixed.
by Anonymous User
Not applicable
Hi Tom,
No this is not currently possible using only a default value, as the entire default value in the field can be edited by the user.
However, have you tried using a regular expression in a constraint field to ensure the value entered matches the format you are wanting, including the degrees symbol and the C. Have a look at: Formulas—Survey123 for ArcGIS | Documentation
Regards,
Phil.
