Camera is not available in
8137
10
12-19-2019 01:52 PM
TahirTamba1
I created a form based on a point feature layer representing inspections on the state of snow removal to complete the survey. To complete the investigation, the field agent must select the point to modify and complete the survey. Everything works well, but when he tries to use the camera to take photos, it is not available in edit mode in the InBox tab. Bellow see attachment for the issue.
When I created the form I set up the camera which is available in the Collect tab form.
Any clues regarding this issue would be appreciated.
Regards,
JayH
Hello Tahir,
Thank you for your support! I made it work..
Cheers,
