Calculations work in SurveyConnect but not online
1438
04-01-2021 09:57 AM
gyetman
I created a form that calculates values based on a user input (via an Excel file). It works fine in the SurveyConnect interface, but when I publish it the calculations do not work: the output is displayed as empty and NaN for the two numbers that are calculated. I'm running version 3.11.123 of SurveyConnect. I'm publishing to the web, the form will be part of a Hub site.
Any hints on how to debug the problem, given that everything works fine in the local app?
RobertBorchert
Honored Contributor
Did you share the form after you published it?
is the Excel file something you created outside of Survey Connect?
gyetman
I shared the form (within the organization) and the excel was edited outside of Survey Connect (created from Survey Connect then edited with Excel).
Jelle_Stu_PR
I also came across this issue once. if I remember correctly it had - in my case - to do with concatenating two string. In excel the string is concatenated correctly using ‘+’, while online this had to be done using the concat() function. See this warning in the documentation of survey123:
gyetman
I only use the + to add numeric values in the sheet. I wonder if one of them is being interpreted as text when it should be a number, I'll check!
