Calculation of sum
793
7
04-05-2025 11:52 PM
DrJumaKhudonazarov
score22
score33
score22
score1010
score1111
coalesce(${q1},0)+coalesce(${q2},0)+coalesce(${q3},0)+coalesce(${q4},0)+coalesce(${q5},0)
I need a formula that automatically calculates the sum on the above table and tells me the service needed or No can someone help. I have tried to use above  calculation but didn't work
Tags (1)
Chris_976
Okay, then you just need to add a select_one question with choices set as 'service_required', 'no_service_needed', set "read only" attribute to 'yes' and use the "calculation" attribute if(${sum}<10, 'service_required', 'no_service_needed').
That will calculate automatically the status based on the sum above.
Christophe AGNES
GIS Head @ Mayotte's public institution for land and country planning
LaurenceTait
Are you trying to do this in a report, or within a survey, or somewhere else? Where did this table come from?
DrJumaKhudonazarov
with connect  ,  report  survey 123 advanced form
LaurenceTait
If you are asking for our assistance, it would be polite if you provide comprehensive, repsonsive answers, rather than unpunctuated and abbreviate, irrelevant single lines responses.
We can't help you if you refuse to provide necessary information, and you may find that some people won't help you even if they can.
So I will try once again:
Chris_976
Hello. Based on what I understand of your question, I created a choice list named 'score' and used it in 4 select_one questions as shown below.
 The formula then works just fine :
Hope it can helps !
Cheers
Christophe AGNES
DrJumaKhudonazarov
Dear Christophe AGNES,
Thanks indeed helpful. I just don't want to  sum  but also create relationship if  score less than 10  service required if more than 10  No  service  needed
Chris_976
Christophe AGNES
DrJumaKhudonazarov
that is great  thank you very much  sorted out now
