Calculation from a select_one question to choose select_multiple answers
576
09-28-2023 09:19 AM
StevenHughes44
New Contributor II
I have survey that creates test request forms and I want to select answers from a select_multiple question based on the answer of a select_one question.  The formula I'm using is from an existing post and is laid out like this:  if(selected(${test_req},'DOT'),'UrineLab,OralRapid,',")
When I save the file, I get a "couldn't understand the expression starting at this point: ...ab,OralRapid"
I have attached the source file for review.
DougBrowning
MVP Esteemed Contributor
Try a space vs a comma since that is how select multiple are stored (and why the values can't have spaces).
if(selected(${test_req},'DOT'),'UrineLab OralRapid,',")
Hopefully that does it
StevenHughes44
New Contributor II
Thanks for the reply.  I'm still getting the same error message after making the change you suggested.
DougBrowning
Opps sorry you had an extra end comma I forgot to remove
if(selected(${test_req},'DOT'),'UrineLab OralRapid',")
StevenHughes44
New Contributor II
Thanks again.  However, I'm still getting the same error.
DougBrowning
You had the last double single quote as one double quote instead.
Also it is a comma - sorry been a bit on that.
Your sheet keeps adding a lead ' to the formula and I do not know why.  Some type of corruption.  Changing to all double quotes helped but not sure what is up.
The formula should be - note I moved it right to the field and removed ${calc} totally.
if(selected(${test_req},'DOT'),"UrineLab,OralRapid","")
Your excel may have issues.  Hope that works
