Blank values from relevant are "" in AGOL but Null in ArcPro
366
02-18-2021 08:18 AM
DougBrowning
MVP Esteemed Contributor
In the past the fact 123 uses "" and not null has been an issue.  But now I am seeing that Pro is showing "" as Null somehow.  I am looking directly at the hosted feature service in both.  This actually means needing diff code in AGOL vs Pro to check for them.
In AGOL
In Pro
I am not seeing a domain or anything.  How is this happening?
For Arcade will IsEmpty do it in both cases?
Thanks for any info
XanderBakker
Esri Esteemed Contributor
Hi @DougBrowning ,
IsEmpty will return true if the provided value is null or an empty string. So yes, it should be able to detect them both.
https://developers.arcgis.com/arcade/function-reference/logical_functions/#isempty
