In the past the fact 123 uses "" and not null has been an issue. But now I am seeing that Pro is showing "" as Null somehow. I am looking directly at the hosted feature service in both. This actually means needing diff code in AGOL vs Pro to check for them.
In AGOL
In Pro
I am not seeing a domain or anything. How is this happening?
For Arcade will IsEmpty do it in both cases?
Thanks for any info
Hi @DougBrowning ,
IsEmpty will return true if the provided value is null or an empty string. So yes, it should be able to detect them both.
https://developers.arcgis.com/arcade/function-reference/logical_functions/#isempty
