Basemap Toggler Widget in Survey 123 Map
569
07-12-2024 01:25 PM
Sara_Fatimah
I am creating a survey for users to report potholes. I want them to be able to toggle on and off between imagery and the openstreet map. Is there an option to add a basemap toggle widget on my Survey123 map?
abureaux
MVP Frequent Contributor
I don’t believe so.
You can choose one basemap.
Or you can use a corporate map container (don’t recall the proper name offhand, but you specify the maps in your Portal Settings). This is the default option. When you click the basement button in S123, it is linked to your Organization’s Portal “map container”.
