Issues with Survey123 CSV Export - Question Order, Duplicates, and Deleted Questions Appearing
991
07-15-2024 03:29 PM
Fernanda_Carrillo
Hi everyone,
I wanted to check if anyone has experienced the issue that I am encountering in Survey123. When I download the response data, my CSV file seems to have a few problems:
•Questions are not in the correct order.
•There are duplicate columns.
•Some questions that were previously part of the survey but were later deleted or modified are still showing up in the CSV.
Has anyone experienced something similar?
Tags (3)
abureaux
MVP Frequent Contributor
Questions are in the order they were added to the feature later.
When you delete something from connect, it doesn’t delete it from the feature layer (you need to do that manually). This is done to ensure backwards compatibility… in a sense.
