Automate Work Order Numbers
511
06-18-2024 05:21 AM
ThomasGoodridge
I'm trying to auto generate work order numbers. The work order id should be the current year dash submission number padded with zeros. So the submissions should look like 2024-0001. The closest I got was concat(format-date(now(), '%Y'),'-',count(${location})), which doesn't actually count survey submissions.
abureaux
MVP Frequent Contributor
There is a blog post that covers this: Creating 'Ticket Numbers' in Survey123 for ArcGIS
you probably are looking for ObjectID, which you don't get until after you submit. Have a look at the blog.
ThomasGoodridge
I figured it out! You have to create a new survey based on the original one, delete everything that aren't the work order number (bind::esri:fieldType esriFieldTypeString) and objectid fields,(bind::esri:fieldType null) , and input this calculation into work order
if(string-length(${objectid})=1,concat(format-date(now(), '%Y'),"-000",${objectid}),if(string-length(${objectid})=2,concat(format-date(now(), '%Y'),"-00",${objectid}),if(string-length(${objectid})=3,concat(format-date(now(), '%Y'),"-0",${objectid}),${objectid})))
