Autocomplete Search return
515
09-29-2025 09:35 AM
ModernElectric
I have an Autocomplete Search function in one of my Survey forms that I constructed from Survey123 Connect. However, even though the data is in the AGOL Hosted table, it seems there is a limit in the number of matches it will return. I the highest number in the field that it searches for a match to return attributes is 3800ish. Howver, the match and return of the function seems to stop when I get close to the higher numbers.
Is there a limit or a "constraint" on this function that is holding me up?
EDIT: Is it easier and/or more efficient to run the PullData and/or AutoSearch function(s) from a hosted table OR from a hosted feature layer on my AGOL account?
Thanks
Neal_t_k
MVP Regular Contributor
Area you saying that the search is returning potentially 1000's of options.  Features layers have a Max Record Count and a query will not return more than that by default.  I haven't tried it myself, but it appears you can manually increase it.
https://community.esri.com/t5/arcgis-online-questions/maxrecordcount/td-p/1255858
https://community.esri.com/t5/arcgis-enterprise-portal-questions/updating-maxrecordcount/td-p/763477
https://support.esri.com/en-us/knowledge-base/problem-unable-to-edit-the-maximum-record-count-for-fe...
ModernElectric
@Neal_t_k
Thank you for the reply. However, doesn't seem like any of these options are working. Doing a search on the forum(s) is retrieving old and outdated results.
Curious if there are other solutions?
Neal_t_k
An alternative could be to try and narrow your search results.
