maxRecordCount
17806
18
02-07-2023 11:58 AM
Paco
Another question about maxRecordCount.
My AGOL Hosted point Feature Layer only allows up to 1000 selected features in my Webapp.
Like many others before me,  I have tried updating the Service Definition maxRecordCount to a higher number(10,000) and save,  but the selection still stays at 1000.  and it also reverts back to 1000 in the Service Defintion.   there are a few places to update that maxRecordCount in the definition, and only one of those reverts back to the lower number.
ESRI can we please get an explanation on Selecting AGOL Hosted Features?  please advise how to raise that maximum selection.
thx!
HollyTorpey_LSA
Are you certain that you selected the desired layer within the feature service and updated its maxrecordcount value? I believe you need to do this even if your feature service has only one layer. And then I think you may also want to update the maxrecordcount for the parent service so that it's at least as much as the maxrecordcount of the layer it contains.
- Holly
KenBuja
MVP Esteemed Contributor
When you updated it, did you also set the lastEditDate value to null in step 7 of the instructions?
Paco
Yep.  would i need to update All of the "_lastEditDate"s?
"lastEditDate" : null,
"schemaLastEditDate" : 1675798413474,
"dataLastEditDate" : 1675798413474
still,  everytime I go back to check the Definition,  the null is gone and the max count is back to 1000
KenBuja
When I needed to change it, I only modified the lastEditDate.
HollyTorpey_LSA
- Holly
Paco
Yes.  I am opening the specific Hosted Feature Layer in AGOL(using 'View' URL on the Overview page.   which gets me to the ArcGIS REST Services Directory,   and clicking on "Admin" in the upper right, and clicking on "Update Definition" at the bottom.
searching for and updating "maxRecordCount" and "lastEditDate"(10,000 and null) and clicking on "Update Service Defintion".
going back to my Experience Builder application,  the selection box still only allows 1000 features.  and if I go back to the Service Defintion,  those updates have reverted back to 1000 and random numbers again.
has anyone gotten this to work with their AGOL Hosted Feature Layers?  does it only work in Portal?  any ideas?
thanks again!
Clubdebambos
MVP Regular Contributor
Hi @Paco
I use the Python API to set the maxRecordCount for individual layers in a Feature Service as shown below.
from arcgis import GIS
from arcgis.features import FeatureLayer
agol = GIS("home")
update_dict = {
    "maxRecordCount": "10000"
item = agol.content.get("FS_ITEM_ID")
for lyr in item.layers:
    print(lyr.properties.name)
    fl = FeatureLayer(lyr.url, agol)
    print(fl.manager.update_definition(update_dict))
You can then check that this sticks by printing out the maxRecordCount property for each layer.
agol = GIS("home")
    print(lyr.properties.maxRecordCount)
~ learn.finaldraftmapping.com
jschuckert
@Clubdebambos , do you know if you can set the parameter to something other than the default at the time of publishing with the Python API? Or can you only update the parameter after publishing with the code you have outlined?
Clubdebambos
Hi @jschuckert,
Apologies for the delay, there was a long period there I was not getting notifications so had no clue if I was being tagged or responded to.
While I have not tried setting the maxRecordCount at publishing, the documentation for the publish() methods states you can via the publish_parameter parameter. More info here.
If using ArcPy to publish from an APRX you can also set the maxRecordCount.
All the best,
Glen
ErinHourihan
Thank you for sharing this solution! Worked perfectly!
