I have a form that is set up to track hours worked on specific projects. There are two questions asking for time, one asking for a sign-in time, one asking for a sign-out time. Both are formatted as a dateTime. I have a follow-up question that is read-only and has a calculation attached to it to display the total hours worked between sign-in and sign-out minus 30 minutes for lunch. The calculation for that field is:
(decimal-time(${time_out}) - decimal-time(${time_in})) * 24-.5
This calculation works flawlessly in both Survery123 Connect and the ArcGIS Survey123 app however if I were to open the survey in a web browser, the hours worked question does not populate. I have a few other areas in my form that have calculations to auto-populate responses and those work fine in both the web version as well as both app versions but no other calculations that handle time specifically.
